First post to your forum.
I have a 1996 Mercury 150hp carburated engine. I had the engine warning beep go off yesterday. It was a constant beep-beep-beeping (ie. not intermittant) however it is not a constant horn (ie. it is definitely a beep-beep-beep sound). Is this a low oil or oil injection warning, or is it the overheat warning?
Here's what happened exactly. Engine ran fine yesterday for a cruise at about 3000 rpm for about 45 minutes. Shut off engine for about an hour then restarted and ran at idle speed for about 5 minutes and the warning beep-beep-beep went off. Checked the oil resevoir on engine and it was full to the top, remote oil tank is half full, checked the water pump tell-tale and there was a constant stream of water.
Shut down engine for about 15 minutes and restarted and no beep. Went at 3000 rpm for about 15 minutes, engine ran and souned fine and no warning beep-beep, then slowed to idle and the warning beep went off again. Shut down again for about 5 minutes and restarted and no beeping again.
I am puzzled, again is this an overheat or oil issue? Any suggestions or fixes.
Thanks in advance for any help!
