Lakefisher420
- Joined
- Jun 21, 2004
- 26
I have a 94 3.0 mercruiser and I have to change the Engine Water Pump. My question is do I have to raise the front of the motor or can it be done with-out undoing the front motor mount? Do you also need a tool to pull the pully?<br /><br />2nd question is I am having a problem with the motor cutting out not stalling. It runs good for about 30-45minutes the it starts to act up on me. It will run all day at lower RPMs but as soon as it hit 3000+ it started bogging. I have replaced all the filter in the carb and added a water seprator and ingnition coil and new thermostat and cleaned vent hose from tank and cleaned carb. Still doing it. I am thinking it is the fuel pump by reading some other post in here. Or could it be just a timming issue? If anybody could help me out that would be great thanks for the help.
