engine weight
LuckyPenny
would anyone care to venture a guess on how much a 1977 chevy 350 weights? this is with the manifolds, heads and accessories (alternator, fuel/water seperator, and power steering pump) removed. Just the block, pistons and crank shaft.
KnottyBuoyz
Re: engine weight
Dry weight for the complete engine is 402 lbs. Heads, intake, carb, manifolds and accessories off would probably still leave about 250 - 275 lbs. Maybe.
Boomyal
Re: engine weight
Probably about 300-350 lbs would be my guess. I think that 402 for a complete motor is low. Ford 302's weigh more than that. But then I'm just guessing.
ron7000
Banned
Re: engine weight
I use an old v-8 block, it may be a chrysler 318, for a mooring. It's just the block with the crank in it and all pistons, I can pick it up deadlift so I'd say around 170-200 lbs from knowing what I could lift in my younger years. Maybe I'll weigh it if i get a chance.
Re: engine weight
I think a Short Block would be in the 300+ range........
Silvertip
Re: engine weight
I agree with Bondo (give or take a bit). A fully dressed 350 auto engine is in 550# range.
JasonB
Re: engine weight
Not sure about a 350 bowtie, but a 302 Ford with a #1 drive, fully dressed, is listed at 984lbs dry according to my boat mfgr is 1976.
tie_one_on
Re: engine weight
Opps.... reread your post. See you got the heads off. 275 lbs. give or take a few lbs.
jmlloar
Re: engine weight
A complete 350 chevy with no bolt ons weighs exactly 550 lbs
