kylep123
- Joined
- May 12, 2014
- 37
I have the 1991 4.3l Cobra Spitfire with the coil pack system on it. I recently replaced the starter and all was well until yesterday we pulled the boat to shore took a few minute break, went back out to start it and the engine turned over once then clicks. Figured it to be dead battery, went home checked battery,that was fine...so I figured I would try and jump start it, the engine turns over fine when I have a running car jumped to the boat battery. Although when I disconnect the terminals to the battery and just connect them to the jumper cables with the running vehicle battery it does the same thing just turns once then clicks...I could really use help with this one, I am going to bypass the slave solenoid tonight and go through all connections just to make double sure even though I just replaced the positive wires and checked the ground less than a month ago. Any Help would be much appreciated. Thank you
