I have twin 200 HP Mercury Off Shore Engines. When I turn my key on for my port engine, it gives off a solid tone before starting it. And when I do start it, solid beep remains. When I turn my key on for the starboard motor, I get the beep, beep, beep and when I start the starboard motor, beep, beep, goes off. From what I recall from the forum responses, solid beep is heat related while multiple beeps is oil related. I did start the port engine and let run. Had good stream and never showed a problem on the temp gauge. Do these alarms go bad? Any ideas on what could cause the solid tone especially when I just turn the key to the on position (not turning the motor over).
