I cannot get the motor to heat up. Tried two thermostats and two different temperature sensors. Both thermostats and sensors were used. I noticed this the other day in the water when I saw the temp just above 100. Boat always ran around 160.
Assuming the thermostat was good, what can create this?
I will try a new thermostat tonight, but I am not confident this is the problem.
The temp gauge is accurate. I checked it with a surface probe and was within 10-degrees. I measured 95 with the surface probe.
Testing has been done in the driveway on muffs with 65 degree water. Water was 62 when I noticed it originally.
Seems strange that I cannot create heat even at an idle.
