engine won't start when hottt
mariner45hp
i have no problem starting it when engine is cool. after running it 1/2 hr or so and engine get hot it will have problems starting. its shooting out steeming hot water. wait 1/2 hr or so and enine cools down then it have no problem starting again. wher can i start trouble shooting???
Lone Duck
Re: engine won't start when hottt
Check your cooling system. NOW! Start at the lower end intake screens impeller, cooling tube, Flush block, check tell tale. Yer gonna seize er!
yorkserv
Do you remember when was the last time you had the impeller changed
mariner45hp
i only had it for a year, and haven't change it yet. having problem getting a manual for it.
AMD Rules
Definetely sounds like its overheating. Don't run it without confirming the cooling circuit is functional.
1987 45hp Mercury
Mercury Service Manual p/n 90-86135--5
This is available a variety of places online, through your local marine service department, by contacting Mercury directly, or can be found used on eBay quite often. Might even get lucky and find a copy at your local library.
I strongly recommend the factory manual, but you could also consider using an aftermarket version such as Seloc. iboats sells that one:
Mercury/Mariner Outboard Tune-Up & Repair Manual - Mercury Outboards, 40-115hp, 3-4 Cylinder , 2 Stroke Models, 1965-1989 Part # 1406
AMD Rules
Yes, only difference is paint color & decals.
