I just installed a radio in my boat. I tested the radio and everything appears to be working properly. I then went to crank the boat up to figure out how it sounded at speed and the boat wouldn't start. It would turn over but would never fire. The coil was warm so I assume it was getting juice which should mean that the spark plugs were getting juice but I can't confirm that for sure.
Anyway, after some thought, I unplugged the power cables from the back of the stereo and the boat fired up instantly. Plugged the stereo back in and it wouldn't start. I currently have the radio wired as follows: The memory backup wire (yellow) is connected to the constant 12v source going to the ignition switch. The ignition wire (red) is connected to the other side of the ignition switch that powers all the gauges when the key is in the on position. Finally, the ground wire (black) is connected to the ground wires for the gauges. The gauges operate properly when I'm cranking. I'm not running an antenna.
Do you guys see a problem here? How is this preventing the boat from starting? The boats power and ground wires are 12-14 gauge and the wire to the radio is probably 16-20 gauge so it can't be sucking that much power...especially when it's off.
