1963 Super Skeeter. Fiberglassed marine plywood to inner hull using 2 layers of 1.5 oz CSM and polyester resin. Plywood sits flat on the hull. No stringers.
Last night fiberglassed the top side of the sole using a layer of 1.5 oz CSM and layer of 10 oz cloth on top of that.
This morning, I could feel a little texture from most areas of the cloth except in an area where I spilled some resin and the excess caused the surface to be smooth as glass.
Now I am wondering if I have enough resin in those areas where I can feel some texture. I wet it out until it was clear but maybe the plywood soaked up more than I anticipated.
I plan to paint the surface with Rustoleum primer and top sides marine paint when done.
Is it a problem to just add more resin to end up with a smoother surface or could that cause problems?
Thanks,
Thanks,
