I need to figure out, since it's an after market upgrade, if they routed the hoses correctly.<br />It looks like fuel is taken from the top carb fuel bowl to the bottom two carbs float bowl.<br />Reading in the Seloc manual it should be the other way around:<br />
in the image is where they tapped into the top carb<br />Enricher System Late Models:<br />The enricher system accomplishes the same function as the old hand choke method by providing an initial rich fuel charge for starting a cold powerhead.<br />The system consists of an electrical enrichener valve mounted port or starboard of the top carburetor. The valve is gravity fed with fuel from the float bowl of the top carburetor. When the ignition key, or choke knob, is activated, electrical current is supplied to the valve. The valve opens and allows fuel to pass from the float bowl of the top carburetor through the valve and into the fuel bowls of the other carburetors. p.4-5
