reynold460
- Joined
- Apr 25, 2008
- 103
hi guys i have a 1989 115 hp 4 cylinder mercury outboard serial number oc106992 and i was replacing fuel lines and i took apart the enricher valve lines now i cant remember where the line goes that feeds the valve it goes to a tee should it go between the carb lines somewhere? . the other side is still hooked up to the side of the block
