Envinrude 48HP. Idles perfect but coughs and splutters at any other RPM
bdd
Hi guys this is my first post hope I'm in the right spot.
I purchased a 1996 Envinrude 48hp SPL E48ESLEDC to fit on my 14' Rib boat. I hooked it all up replaced the water pump and rebuilt the carb's because it was running crappy past idle. After the rebuild it was still running crappy at any rpm past idle so removed the carb's once again, cleaned them, and made sure they were assembled correctly. All looked good however there was dirt in the carbs this time so I cleaned them once again replaced all the fuel lines, cleaned out the fuel pump, added a inline fuel filter, and gave it a good flush with clean gas before hooking up the lines..
It has new plugs, 140 psi in each cylinder but I still have the same symptoms.. Any Ideas?
