JSGOLD
- Joined
- Sep 22, 2009
- 609
We replaced our 8hp tiller motor with a newer Mariner 9.9 remote steer and I did a stupid thing by buying a new Attwood fuel tank that apparently has no ventilation cap. I installed a new mercury hose with the nipple on one end as I figured this was a better connection that I had on my Evinrude(it leaked sometimes when cold) and what I find is that this tank swells up, even with a small amount of fuel in it and fuel escapes around the nipple. I just came back from removing the battery and found a puddle of gas on the floor....And it has done so one other time while sitting in the garage while we had the 9.9 on a engine stand. I tightened the hose well, but ti still leaks it seems. Does not seem to matter if the cap is tight or not it still swells unless the cap is darn near off. let my vented tank go with my 8hp, any ideas? i dont think you are supposed to use sealant on those nipples, but may be wrong. I also noticed hesitation on the 9.9 when we used it the first time. I wrote it off as perhaps a dirty carb, as motor has not been used much except as a kicker. But the motor idles well, and when it gets going it runs great, no misfires, nothing. it runs slow and high speeds well after it gets warmed up. Perhaps still a carb issue but I wonder if the tank can be causing this as well.
