I am planning to mount a 12 gal. fuel tank under the front seat of my 13' Whaler. I will hold it in place with straps anchored to the floor. My plan is to drill 7/16" holes thru the inner floor, dig out some of the foam core around the perimeter of the hole, vacuum out the loose stuff and then fill the hole with epoxy. This will give me a reinforced area to drill and screw my mounting blocks into. There seems to be so many choices of epoxy that I'm not sure what is the best type to use for this application and should I add a filler material into the epoxy for added strength? Happy to hear any advise, thanks.
