I'm finishing up a floor replacement, and am finding myself under some time pressure to get the boat out of its current location. I need to finish tabbing the deck to the hull, then need to put down self-adhesive floor covering (Hydroturf with 3M self-adhesive backing, and Dap Weldwood around the edges). My question is, how long should I give the epoxy to cure to the point that it will no longer be producing blush, before I scrub off the blush, and then apply the floor covering? (While I'm in a rush, I don't want to rush it, and end up with floor covering that doesn't want to stay down due to blush continuing to develop while or after its being put down.)
I'm using Total Boat 5:1 epoxy with their slow hardener. The temperatures will be in the mid-80's, and the humidity will be around 50-60%. The 'Thin Film Set Time' for this epoxy/hardener is listed as 10 hrs at 75 degrees. The 'Thin Film Cure Time' is listed as 1-4 days. When I've been working with this epoxy, I give it at least 14-16 hours before the next coat, scrubbing the blush off before the next layer goes on, if I'm not able to do a wet-on-wet layup, and that has thus far worked well. (ie, everything has adhered well, is very clear, etc) I will note that it typically takes a full 24 hrs for it to lose all rubberiness, and get fully hard and a little more brittle.
Would 18 hrs likely be enough time before putting down the floor covering over the tabbed edges and seams between sheets? 24 hrs? several days? As noted, I'm under some time pressure, but not so much that I want to risk screwing the pooch at the very end of this project, by installing the floor covering too early.
