Hi All,
My dad gave me his '70 Alumacraft w/ a newer Erude 130. Already replaced the stringers deck, gauges & wiring.
I am nearing the end of repairing some hull damage. I have ground down the bad spots at the bow and re-patched a few poorly done repairs with layered fiberglass mat / epoxy and filled in with bondo to make nice & smooth then one last layer of glass.
The rest of the bottom is 3 layers of peeling paint. I will sand down the paint to a single solid surface and probably coat with epoxy.
Should I layup the entire bottom glass mat & epoxy?
The boat is trailered and only occasionally used during summer months in fresh water.
Does the epoxy NEED to get painted?
Ca it just get waxed?
If it needs paint, what is a cost effective paint to use?
THNX!
THNX!
