wineyarders
- Joined
- Jun 22, 2011
- 46
Hi,
I posted in the Suzuki forum with one good suggestion but thought I'd check in with the johnnyrude crowd. I have a couple mid 80s 15hp and thought there might be some insight in this forum given some comparable design features. Anyone know of a good epoxy made for fuel exposure that I can use on the inside of a carb to repair a non load-bearing aluminum break? Many thanks for any advice,
Ryan
Here's the info from my previous thread:
http://forums.iboats.com/showthread.php?t=555841&p=3818202
I have a 2000 Suzuki 5hp that needed a carb overhaul. Unfortunately I broke one of the aluminum arms that supports the float hinge pin. I have the part and could reattach it easily if there is a bonding agent that will resist having the exposure to the fuel. Can anyone refer me to a material that will bond the aluminum while holding up to the fuel exposure? I have jb weld on there now but don't have a whole lot of confidence it is a long term solution. Also, a new carb is about $150 so not a huge expense, but one I'd like to avoid if there's a solid alternative. Thanks for any advice.
Ryan
Ryan
Ryan
