Epoxy on Regular Everyday Woods?
GregE
I've read alot about epoxies on this site today. Something I didn't see mentioned (likely for good reason but I'll ask anyway).
For customizing the inside of an aluminum jon boat, and seeing as a quality epoxy is as good as it is (such as CPES) at sealing wood, is there a true need to use marine grade woods?
Would normal everyday plywood and other non-treated lumber hold up if sealed with a couple of applications of epoxy?
Not that I'd go that route, but the question comes to mind.
tashasdaddy
Re: Epoxy on Regular Everyday Woods?
i have used exterior ply and just painted on several aluminum boats, keep it painted, no problem.
Lone Duck
The reason for marine grade plywoods is for strength (no voids between plys. ) epoxy is used for glueing and moisture proving . once moisture gets in, the type of wood regulates how fast it will rot. ( douglas fir verses poplar) pressure treated wood is good for rot but its ply,s are full of voids. so you would not use it for a strong bottom.
