Epoxy or Polyester ?
REEFKEEPA
Which resin is best for outside corner repairs on a semi stressed area? example: The edge of a console.
Terry H
Re: Epoxy or Polyester ?
I like the poly much better too. Chief ;)
Buttanic
Epoxy is stronger and bonds better than poly. I find it easier to mix and use than poly and very little odor. Down side is it is more expensive. I just finished a deck replacement and used epoxy for the first time and I don't think I would go back to poly.
prockvoan
If the area is not to big with no cracks,just use some fiberglass putty,geocoat it after.
jim dozier
If you are patching polyester resin you can probably just use polyester resin. Its less expensive and cures faster so you can put multiple layers on in 1 aftenoon. If you are working with wood and polyester I would go with epoxy. When working with wood epoxy bonds better to wood than polyester. Epoxy is also more flexible than polyester which is another reason it works better with wood. Boats are usually built out of polyester resin because it has adequate moisture impermeability, is less expensive, and easier to work with in production lines. High end composites for boats, race cars, and airplanes are usually made out of epoxy because it is stronger and has a higher bond strength.
REEFKEEPA
It's a repair of a split outside corner edge of a polyester layup I did about 11 years ago. I'm not sure why it split on that particular edge but I want to fix it for good.
jim dozier
Can you get to the backside of the damage? Usually patch failures occur because there wasn't a large enough bonding surface and/or there wasn't enough glass across the damaged area. The resin is just used as a substrate and bonding agent for the glass which has the strength. That's why cracks reappear if you just fill them in with resin, particularly if the original glass beneath them has fractured. Small dings can be repaired with epoxy and glass filler, but if its bigger and or the underlying glass has broken you really want to glass the backside for strength and then fill the topside with filler for cosmetics.
jimmythekid
nice av reefkeepa, like a rainbow in the dark, Im always the last in line........<br /><br />by any chance do you have a aquarium?? I was just wondering due to your name.
airman
Don't forget that once you choose epoxy, you're stuck with it till you die... Epoxy will bond to poly but you can't do a poly repair or addition to epoxy.
