Erratic Tach
Snipe
The 50HP Mariner mounted on a pontoon has an erratic reading on the tach. It runs steady and smooth, no miss or carb malfunction, but as we cruise (1800-2000 rpms) every once in a while the needle will jump close to the top. Then it will be alright for a while and jump up again never missing a beat. It's been like that for a couple of years now, no other problems. :confused:
Trent
Re: Erratic Tach
Charging the battery ok? Tach is electrically connected to the charging circuit. Eratic tach is the first indication of charging system problems.
Snipe
Re: Erratic Tach
Thanks for the input.........<br />The batt. meter does show charging @ about 16 amps. If I turn the running lights on it will go down to just over 14. That's running at over half throttle.
