erratic tachometer readings
Edge180
My tach works most of the time, but some times it's erratic and other times I watch it go beyond the capable guage (like past 7,000 rpms) all while the engine remains normal.
I'm assuming this is a grounding issue but don't know where to start. Any help is greatly appreciated.
JoLin
Re: erratic tachometer readings
At the rear of the tachometer is a small screw (the pole selector switch) that's pointed at a specific number, like 2, 4, 6, etc. A little corrosion there can produce the symptoms you describe. It's happened to several folks including me.
Take note of the number it's pointing to, then with a small screwdriver move the switch back and forth a few times. Set it back to where it was originally and try it out.
pole position
JoLin is correct.My Carver does the same thing,one side or the other and this works.It happens about once a season to me.
MH Hawker
Yea mine is doing that right now in fact and thats on the work list.
Edge180
Excellent. Thanks fellas.
