eska remote fuel tank
maddog12
anyone know what fitting i need to connect a remote tank to engine or where i can get one for a eska 4.0 gamefisher
Is there a fuel pump on the engine?----Convert it to use fittings off any common brand of motor?
matt167
You will need a fuel pump. Not sure what Eska used for a pump but most outboards use pulse pumps. My 2021 Suzuki 25hp uses a mikuni pulse pump to pump from tank to the float chamber where it’s efi pump is. same pump as my lawn mower.
The small square pump used on 3 to 25 HP Johnson / Evinrude would be easy to adapt to the crankcase.
