Troubleshooting a possible ignition problem.
Using the jumpered EST timing procedure, I set the base timing to 1' BTDC, and then when removing the jumper, rather than going to the idle timing of 12'BTDC, it jumps to nearly 22'. I would think this is a problem with the module, but I tried another and it does the same exact thing. In fact, I've tried a different distributor and ignition coil as well.
Anyone know what might cause this?
