EST Ignition Shift Interrupt Switch Wiring
tschmidty
I have converted from a points distributor to a HEI EST iginition (got a deal on a whole wiring harness + distributor and alternator setup). I have it running, set initial timing etc., but wanted to confirm the shift interrupt wiring.
I am almost positive that the EST sends a 12V signal to the distributor over the white/green cable to cut the ignition as opposed to grounding the coil like the old setup. That's what it looks like from the wiring diagram and what I vaguley remember reading here (but can't find). Just wanted to double check with the experts before I wire it up/test it out.
Don S
Re: EST Ignition Shift Interrupt Switch Wiring
Here is the wiring diagram you need, along with setting and troubleshooting procedures.
I highlighted in yellow the timing and specs you should use with your older engine.
  • 3.0L EST.pdf
tschmidty
Excellent, thanks as always for the advice.
