Etching Primer: What does it do and do I need it?
N62350
I am slowly ( VERY SLOWLY) restoring my 1959 Starcraft Speedqueen, and I am ready now to paint the bare aluminum interior. Do I have to use etching primer, or can I get away with regular filler primer? Does etching primer work on steel?
69rrvert
Re: Etching Primer: What does it do and do I need it?
When I sandblasted and repainted my aluminum boat 7 years ago, my paint guy recomended the self etching primer so that is what I used. I am not sure what it does, but ut still looks good as new today. Thanks, Steven
archbuilder
If you don't use it the paint will peel off. It also works on steel, but it is always a good idea to give either metal some "tooth" with sand paper. If you don't use it on the aluminium, I promise you the paint will come right back off! Make sure you follow the directions, prep is the key to painting, good luck with your project!
