ETEC Emm Issue
Enephew37
I have a 2006 Evinrude Etec 40hp tiller boat motor. The Emm is getting no power none of the lights are coming on so I was wondering if there was a way to test these like seeing if the power wire to power the emm is getting 12volts or not and if it is I would assume it would be a bad emm. Is this a good way to test it? If so, where would the power wire be that hooks up to the emm?
Enephew37
Yes it does I’ve checked the ones I’ve found and they don’t seem to be blown
Chris1956
I saw a video of a guy working on a FICHT, which is the father of your motor. It has 4 fuses in a plug, attached to a cable. The fuses were under a cover, that looked like a cable terminator. You might look for such a thing, if you did not find 4 fuses together.
saltchuckmatt
"don’t seem to be blown"
Test them with a electrical meter.
This is what you want to say,
"Fuses are good"
