Re: Ethanol and Premix
Geez folks -- lighten up. This thread was about three things. Ethanol, its horror stories, and using it in pre-mix. I simply tried to provide a little humor and extreme examples. Sorry! We in the midwest have used the stuff in outboards, inboards, I/Os, chain saws, lawn mowers, our cars and tow vehicles for years. It may cause some initial problems but once the system is cleaned the engine will live nicely. And since ethanol is such a good cleaning agent, you will very likely have fewer fuel related problems in the future. Yes -- there are some fiberglass tank issues. Times change so some of you may need to reach a little deeper into the wallet to overcome those issues.
If you have oil injection and run the carbs dry the VRO may fill them up with oil. Since multiple carbs may not run out of fuel at exactly the same time some cylinders will run dry -- also not a good deal. Treat the fuel, turn the engine off and it will be fine until the next trip.
