I read with interest the sticky post about Ethanol E10 gas being an acceptable marine fuel and that it may in fact be a better fuel than E0 for marine use. I would submit that the millions of dollars that are spent each year dealing with the results of this fuel stand in absolute rejection of this notion. Any fuel that, when combined with water, produces a solution that can attack the insides of the fuel delivery system and cause corrosion that can flake off and clog screens and injectors is definitely not marine-friendly.
A local outboard mechanic, who fishes quite frequently, takes apart his VST three times a year to clean out the screen to the high pressure pump to remove flakes of corrosion so that he doesn't get stranded on the water. I have had to do this job three times myself over a 6 year period and it takes me half a day to do it (I am admittedly slow). This marine repair shop has added that procedure as part of their standard maintenance list, and they tell customers if their gas is older than a couple of months, pump it out and put it in your car/truck.
On that note, my question to the Iboat brain-trust is: Does anyone know of a coating that can be applied to the inside of the VST to prevent it from being attacked by this Ethanol/water solution? This could prevent the corrosion that clogs the screens and injectors of these motors. I have to wonder if new motors might have something that can stand up to this problem, since it has been around for a while now.
