dkonrai
- Joined
- May 9, 2009
- 719
my recent adventures on purchasing a 88 6hp longshaft evinrude. it ran and idled great, but, did not want to throttle up.
ended up that the throttle cam arm was broken a common item that breaks. replaced the cam then the motor still did want to throttle up. i didnt really want to pull the carb due to the recoil starter is a pita. pull the carb and primer. primer is closed due to carbon and this slimy fiber like stuff. it was all over and in the fuel system. the fuel pump was clogged as well. my assumption is the previous owner never ran seafoam or stabil. i have pulled at least 30 carbs apart and this was one of the worst i have seen. blew carb cleaner through every orifice, as well as small strands of wire.
ethanol is really some bad stuff. amazing this little motor ran at all. i know i paid way too much for the motor, 180.00 but its pretty clean on the inside and seems to be a low hour motor.
http://www.youtube.com/watch?v=ajVZ6DgIMiA&feature=g-upl
dino
dino
