Re: ethanol
If your fuel system has been kept clean until the time you started using "corn squeezins" chances are you'll not notice any difference. As the Major says, if the tank, lines, carbs have gunk in them, chances are that material will be loosened. Do not run the engine if it begins to act up as it will be due to a lean condition. That can cause problems. Rebuild the carbs, replace filters, clean the tank and you'll be good to go. We've been using the stuff in the midwest for years with no problem (except in dirty engines).
