Re: ethenol gas
Never heard of Gas Shock, but will try to find it and give it a shot. If Dhadley says it works, then it works.
I've been using Star Tron for years, specifically for treating Ethanol. Stabil isn't gonna do squat for Ethanol, unless you buy the specific Stabil Ethanol treatment, but even then I'd still trust Star Tron over it.
troypb.....I'be bet the reason you haven't seen the problems that the PO did, was that he dealt with all the intial Ethanol problems. When it first started coming out and being used, it would lossen a lot of crap up in fuel systems, tanks, lines etc..
Once a few tanks of the stuff was run through and lines, filters and whatever else needed to be changed, were changed, usually the problem went away. So the PO of your boat probably had all the initial problems, had them fixed and now your fuel system is clean.
Keep good clean fuel/water seprators on it, don't skimp on them and make sure you change them every year, use Star Tron all year long, both when using it and storing it and you'll be good. The plastic carb bowls don't make a difference either way when it comes to Ethanol. I've been running both the metal and plastic bowls for years on Ethanol and have had no issues with either.
