ethonal resistant fuel lines
oxbeast1210
Hello I would like to replace the fuel lines that go to my motors carbs
its an evinrude tracker 150 hp I was just wondering where i could purchase them? and if its an easy swap?
thank you!
Ike-110722
Re: ethonal resistant fuel lines
Just buy OEM fuel lines and they will be ethanol resistant. Most of the new hose complies with EPA requirements for evaporative emmissions which means it is ethanol resistant.
richos
I was told NOT to put ethonal in my boat...
because of something to do with water if it gets in the fuel
5150abf
Ya, just find out what sizes you need and go to Napa or AutoZone and they can set you up.
Remember to replace all the lines not just from the tank to the engine, alot of guys forget about under the hood.
F_R
They don't make non ethanol-resistant hoses any more. At least not any reputable manufacturer. Ethanol has been around for years and is a fact of life. Might as well get used to it.
GaryO
I was wondering, don't the fuel lines have to be approved for marine use? If so, does NAPA or Autozone carry that type?
tashasdaddy
an consealed lines have to be marine. as in inboard, inboard/outboard. or built in fuel tanks.
oxbeast1210
Thanks guys for the help I didn't realize that most lines
Now are already resistant all my main lines are new just wanted to
Make sure the all the little ones were to
Thank you!!!!!
Ike-110722
you need to read up on the ethanol issue: http://newboatbuilders.com/docs/Ethanol.pdf
The fuel industry has been putting Ethanol (spell that Alcohol) in the gas since the phony oil crisis of the 1970's The USCG , the American Boat and Yacht, Society of Automotive Engineers (SAE) and National Marine Manufacturers Assoc (NMMA) got together in the 80's and developed a new alcohol resistant hose for marine use. Since then the EPA has stepped in and made the hose even more resistant to vapor migrating through the hose.
So as all have said, just go buy some new hose, and replace all of it. Hose should be replaced every few years anyway, especially if it's exposed to sunlight. It is not very UV resistant.
