evenrude 135hp outbord water pump
searcher001
I am replacing the pump and now that I have the new kit, it appears the impeller will is larger then the housing. The manual gives steps to reassemble but no illustration. What am I doing wrong? :eek:
BIGKASH
Re: evenrude 135hp outbord water pump
the impeller is usally larger it get squash everytime it rotates in the offset pump circle. and being squashed it pumps water out...it made out of rubber so bend it and install it...double check part number though
Jack Shellac
Be sure you bend the impeller vanes the right way. Look at the old one to get it right. The manual should cover this important step.
Walker
Put the impellor on the shaft and slide the housing down to it. Now, while pushing down on the housing turn the drive shaft. The vanes of the water pump will bend as you turn and the housing will go down. It doesn't matter which way the vanes bend. They will get themselves in the right direction the first time you start the engine.
searcher001
Thanks, I will give it a try. It made me a little nerevous to force it in. Now that I know that is the norm.
