Evenrude 15hp model no
Vlantir
Model Be15baenm
Serial No 08916066
According to this it is a year 1992.
When I look at the parts lists it indicates a 1992 thermostat sits at the top and is held in by three bolts.
My thermostat sits at the bottom low in the cowling behind the cowling cover switch why is this. Is this possible to order spares as I am now lost please advise does not tie up to Model Be15baenm.
It has the newer type tiller arm with kill switch on the side with a lanyard the motor has never been rebuild.Which tells me it is a 1992 or younger.Has anyone ever see this what must i do do bass are biting in South Arfica I need to fish pleeeeese.
:confused:
david_r
Re: Evenrude 15hp model no
look around on the top of the block and find a plug about the size of a quater.............that should have the model #---in case someone changed the powerhead.
david_r
it looks to me like it is a belgium made......any way its the 4th 92 from the bottom
david_r
i think its like this isnt it? 15BAEN / 15BALEN 1992
b-----belgium
e-----evinrude
15----15 hp
ba----ac lightning -rope start
en----19992
m-----model run or suffix
Vlantir
HI thanks this is what is on that quater size plug M 393.530 rph does this mean anything to you.Does it tie up Be15baenm.
david_r
sorry i should have said 9th from the bottom--on the list.
its the 1st 92 listed out of the 4.
sometimes my brain doesnt work right!
as for your plug i dont know.......unless someone changed the plug.
maybe someone else can tell you, im lost on that one.
sorry.
Vlantir
Thanks for the help guys made a breakthrough last night contacted the previous owner.The Motor is a 1992 modle.It was rebuild by Bucks Marine the power head was replace.
If one replaces the power head too the older type. Do you have to replace the block as well.Or can just the power head be changed say put an 1986 power head on the 1992 block.
Any idear what power head it is as asked the welsh plug no is M 393530 rph
david_r
the power head is the motor.
the dealer (bucks marine) should have the info available for you on the re-man motor......depending on when it was done and how they keep their paper work.........or maybe someone on here knows how to look them up.
ezeke
RPH is the replacement powerhead and was installed on your 1992 motor. It apparently was the correct short block for your motor and everything else should match the 1992 parts lists.
Vlantir
Thanks guys where do you get all your info that rph block info is great news thanks to all of you.
Have a great Xmas when you come out to South Africa give me a shout will take you out to wet a line cheers.
