I recently bought what I believe is either a Godfrey or Hurricane deck boat, 19' 1983 type. Apparently everything really is bigger in TX, where I bought it, even the "slow leaks". So now, after ripping out all the old flooring, made easier by years of rot, I haven't found wood stringers. Instead, I have two M-shaped FG "stringers" that run from transom all the way forward. They aren't connected directly to the transom, motor is OMC sterndrive, so no transom weight to speak of. The only wood, other than the decking, was several 2x4 pieces that ran perpendicular to them, set into glassed in grooves. I think the M shapes are full of foam, because they have the vent holes drilled in 'em. I know nothing about foam, but I'd be pretty certain mine is soaked. If these are foam, is it possible to dry them, and if not how important would it be to get it out of there? Would there be a way to dissolve it without hacking up the FG? Like everyone else, I don't want to have to go through this again.
