Everything was going well and then...
dj7
Help!
While I was re-assembling my 1964 Evinrude 3 hp Lightwin, I may have over-tightened one of the cylinder head bolts ? one of the corners. I felt it suddenly give a bit. At this point I just left it alone. I was afraid to try and back it out.
So my concerns are, what may have happened. Did the bolt head twist off, did I strip threads on the bolt or in the head or case? Has anyone had this happen to them? What is the most likely occurrence.
Can I just ignore this for now and see if anything leaks out at that place or should I remove it before I tank test it? In the worse case, can it be repaired.
Also, I did not lubricate the new gasket. Should I have done that?
Nova II 260
Re: Everything was going well and then...
All engines have bolt torque specs for different size bolts based on the bolt size and the material they mate with. That said I think you probably stripped the threads in the block/case. You could try and repair it with a thread reapir kit. [url]
Kevin W
90% chance you stripped the threads.
your best option is to Helicoil it.
there are kits avalable and most machine shops can do it very quickly.
basically what id involve is: drill out the old threads to the new helicoil size, tap new helicoil size threads and install the helicoil insert.
They are much stronger than the original thread.
Rudy Brown
What Kevin W said. You can get a heli-coil kit at just about any auto parts store. I had to do a head bolt on my motor a month ago.
