Friend of mine has above motor. The carb is pretty worn. I have a carb lying from a 35 hp 1979 I parted out. I´ve been told this is a better carb, same bore. The 35HP carb has 49D main jet, the original 1973 carb has 72 main jet. Which jet should we use for the 1973, it has less displacement than the 1979 35 HP ? the 72 or the 49D ? Does anyone know ? Is the jet calculated from the motors displacement or the venturi in carb ?
