Went to help a friend of mine who bought a 1977 35 HP Evinrude. It iddled very rough, We found it was leaking at upper cranckshaftseal. Compression 132 on both. Upon replacing this ( without disassembling motor ) it iddles smooth. But it sure has a rattling sound !! Checked if flywheel touches magnetos - it doesnt. When laying force on flywheel from cylinderside of motor, flywheel can be moved app. 1/32". When flywheel is turned 1/4 turn, play is almost none. It must be upper bearing - or do you think cranck journal ? Can he run it with the play - rattle decreases when rpm gets up ? Any opinion is appreciated.<br />We only run it in barrel - on rpr below 2000.
