bscappell
- Joined
- Mar 29, 2010
- 132
So i have searched other posts but mine seems to be a bit different than others. i just swamped power heads and messed with the throttle linkage and now it will start (although not great) but stalls when going into gear UNLESS i pull the linkage to the timer base (i think that is what it is called, see picture) towards the bow of the boat. Once it gets up to speed I dont have to pull on that anymore.
What did i do? i asusme i messed with something regarding the low RPM timing. when swapping out the power heads i kept the motor as intact as possible, only removing the intake forward to rebuild the carbs.
