rustyscrew
- Joined
- Mar 29, 2006
- 141
I have a E115fpxeec 1999 115hp evinrude ficht.
I just started it up to test it after replacing the low pressure fuel pump diaphragm. It was not good. It revved higher than it should. Sounded like it was missing a cylinder or two then stuttered and backfired a number of times and stalled. I didn't investigate further because it was dark and raining, but before I resume I am open to suggestions. Any ideas? Sensors? Bad Injectors?
History:
I got water into the engine that went past the water/fuel seperator in June.
I had it serviced by a mechanic ($850), but when I got it back and hooked it up the the fuel tank, there was a vacuum in the pickup.
I think this damaged the diaphragm on the low pressure fuel pump and I couldn't keep the engine running without hand pumping the primer.
I took it to another mechanic that is supposed to be the best. $2000 more later I have a broken motor still. They replaced the VST and fuel manifold. They were about to replace the injectors but I took the motor back because new injectors are $650 each.
I opened the low pressure fuel pump and sure enough it had a hole in the diaphragm.
I replaced it and that is where I am now....I was optimistic it would be the final fix, but now it runs poorly and backfires.
History:
