Evinrude 115HP, year: 1975, model 115593
This motor ran well before this incident happened now it wont start and I only have spark on one side of the motor. My negative battery cable was loose and while cranking the engine it would not turn over and only make crackling sounds. I got it back home and fixed the battery connection problem. Now it turns over good and fast but never attempts to kick in. I checked the spark and found that I have spark on 2 & 4 cyl but not 1 & 3. The factory service manual I have tells me to use some type of neon tester which I do not have, and can not find, so that is of little help. There is a troubleshooting step chart which indicates, when there is only spark on two cylinders, it is either the power pack or sensor coil. But before I go replacing either one of these I want to do more testing. Can anyone point me to some testing procedures I can do with my multimeter to figure out what I need to fix?
