I am running an Evinrude 120 1989 model. I have replaced the fuel pump and cleaned/rebuilt the carbs and it runs great with the exception of random spells of acting as if it is not getting any fuel..... i can open the throttle and it will just bog down.....after a few minutes of this (and after opening the throttle) it will just go as it should. i think the best way to describe it would be a major fuel restriction then whatever was blocking passes through and it runs fine. i though it was loading up, i can clear the carbs but that doesnt help. a new fuel filter did not help either. would a bad plug cause this? they were replaced last fall. any ideas would be greatly appreciated. <br /><br />i am also trying to get more RPM's out of this 120. I have it on an 89 stratos fs 279. I am running WOT 4900 rpms. I know there is more power to be gained, but i just cant seem to get it to come out. The prop is a 13 1/4 x 21 3 blade ss prop. any ideas here? what would be an acceptable WOT range?<br /><br />Thanks for the help guys.
