Evinrude 120 No Spark Issue
spybot
Hi guys
Been of the forum for a year or so but now need help.
I have an evinrude 120 looper.
She ran great on the muffs
I then removed the VRO as i was going to run premix.
Now after i did this and drove 75miles to the lake.
Now she wont start. I have checked all coils for a spark but nothing.
What i have done so far
Replaced the battery. Was done before i had the issue.
Connected all the VRO wires and hose back up.
Removed the boat side of wiring so i know its not that.
Jumped the starter with the red plug removed Still no spark. So i know it is engine side of wiring.
I removed the one black and yellow wire from under the flywheel to the cdi ( is it the wire from the stator ??? ) Still no spark.
This is an intermittent fault she she fired up for a bout 30 seconds on one try to get her going but died afterwords and wont even give a sign she wants to start again.
Its has the CD3 Ignition system
She has 125psi on all 4.
When she was on the muffs and before i removed the VRO she ran and started first turn of the key.
Am i missing something stupid ???
I know what i am looking for on a Johnson Crossflow but loopers and CD3 is all new to me.
This is driving me crazy Help guys please.
VRO wires and VRO have nothing to do with spark----What do you mean by CD3 ignition on the V-4 ??
spybot
Hi Racer
On the back of the motor is what looks like a cdi power pack. It has CD3 written on it. Theres wires coming from under the fly wheel and connecting to the power pack. I thought i may have dislodge a wire when i was removing the VRO there is a block connector at the back of the Trim/Tilt relay box which i had to separate i dont know if i may have doing something then.
spybot
Sorry Racer the badge/sticker has been pulled off/ worn away. Cant find any thing like the crossflows have like a plug with the serial on it.
spybot
Is there away in which i can eliminate the kill circuit ?
Just so i can rule that out of the equation ?
I feel its a lose wire somewhere, the motor started fine and run on the muffs for 10 mins or so.
Then after the bumpy 70 mile drive she would not start at all.
I had to get towed to my mooring ( only because if you done have a boat on your mooring you lose the spot. I would rather have had her on the hard to do this work but i cant)
I am at my limit of knowledge regarding these looper engines.
As far as the ignition system is concerned it works exactly the same way as a crossflow.-----Only the pieces look a little different.
spybot
So if i disconnect the blk/yei from the connection board (the strip with the all connections in it) The motor should run ??
I understand that if it does run, i will have to cut the air or flood it with the choke to stop it.
If it still does not run this way I may be looking at a new cdi unit ?
spybot
How would you do this fault finding Racer ?
Am i correct in thinking the above ? Should i try a different approach ?
Its the only way i can think of to try and find this fault. You have forgotten more than i will ever know about OMC engines i apericate you taking the time to give me a help out over here in Scotland
Invest in a multimeter and do some checking.-------Parts under the flywheel can be checked without removing the flywheel.------I often recommend to inspect starter motor / clean / replace brushes on these motors.----Usually that gets a negative response from folks who do not know how these systems work.
spybot
I have a meter and will get the settings from the net somewhere. Starter motor was new last summer, polished battery connections when i put the new battery in. I realize that if she is not spinning the flywheel fast enough there aint gonna be a spark.
Thing i may need to build is a DVA to use with my meter.
I have a factory manual on the 1980 Crossflow so will work using that procedure and then hopefully sort the problem out once and for all. I hope its just a kill wire earthing out. Now that would be good news.
I had to get most of the stuff i needed when building my 140 crossflow. (Still not started her for the first yet ) shipped in from the US
Will post my findings on here if i get her fixed
