skibrain
- Joined
- Jun 17, 2004
- 766
I'm having an intermittent thunk from my outboard that I bought used three years ago. ("89 120 Evinrude V4. with OEM type SST stainless 19" pitch prop. on a "89 Glastron CSS-16 hull). the boat/motor has run flawlessly for three summers and the following just started at the end of last season.<br /><br />The thunk occurs when running sometimes at medium increasing throttle, sometimes at sustained 4,000 rpm range when pulling a skier or sustained lower rpm like when pulling a tube. It is not predictable as to occur through a certain rpm range, nor does it tend to occur more at max. load - i.e. max. throttle hole shot when pulling a 200 lb slalom skier up (although it has happened at that time) Trim is all the way down. Motor is mounted securely to the transom.<br /><br />When it happens, there is a barely perceptabe, quick blip increase in rpm, and then a driveline thunk that feels like a gear slipped, and then the motor continues on at the same rpm and boat speed as if nothing happened. I only get one thunk at a time, but it could happen three times running the length of the lake. (3/4 mile). I'm pretty sensitive to mechanical noises and irregularities, but this is strong enough that non-boaters riding with me last fall would turn and ask . "what was that?" <br /><br />I had a reputable marine repair place look at it last fall and they found nothing wrong. They had it under load through all rpms on a hydraulic dyno connected to the prop shaft and found no ignition or drive train irregularities.<br /><br />Other than paying a mechanic to ride along for a water test, I don't know what next step I should take.<br /><br />Any ideas? <br /><br />Has anyone had exprience with a prop starting to spin the hub inside the prop? (i think these have a rubber damper to help shield the driveline in case of a prop strike) If this happens does it let go and hook up (like slipping one cog on a gear?) Maybe it gets warm and slips more under load. I will have to put on my other prop and give it a try.
