Hey all,
I have an 97 Evinrude 130. Sunday I put the boat in the water to make sure it ran good for Monday. Ran good for 4 hours with the exception after idling up the new river for a while when I got to the ramp at idle sometimes it would die.
Took it back to my house checked the plugs, changed the fuel seperator, and flushed the engine. I noticed the RPM was varying a little but didnt think anything of it.
Next day put the boat in the water made it around the corner from the boat ramp and the engine started dying. Every time it died the primer bulb would be soft. Took a ton of starts and playing with the engine to make it back to the boat ramp.
Ive changed the fuel separator again, checked the fuel lines etc. Finally got it primed and a hard primer bulb by putting the bulb vertical.
Ive tried putting my fuel line right into a different tank of fuel.
Checked my compression, all even about 130.
Each cylinder is getting spark.
The engine will start, if you throttle up to 2000 RPM itll vary dropping as low as 1000 or going up to 2500 smoothly. It idles like crap, and sometimes throttling up the engine will just sit at 1000 rpm eventually always dying. Seems to normally not have a hard primer bulb when it dies.
My manual says for timing you need a special tool...
What about the fuel pump, would my symptoms match? I run premix and the oil line is capped. Thinking of taking out the pump and opening it up, should I?
Thanks for any help!:facepalm:
