Re: Evinrude 140 / 1990 idle problem ...conclusion
Could be one of several things (I have 1988s). What comes to mind as possibilities include minor air leak in fuel lines or gas tank connection, weak fuel pump (kind of doubt that if you are able to run WOT though). I would replace all fuel lines, bulb and fuel tank fitting whether they need it or not.<br /><br />Another possibility, which is really why I'm responding, is that somewhere along the line someone may have removed the thermostats and the engine is running too cold. I had this problem. One mechanic suggested that I also tilt the engines up a bit when the need to idle came up. This is to change the angle of the fuel in the carb.
