chevysam41
- Joined
- Jan 29, 2016
- 59
Hello All,
I have a 1976 SS Evinrude 15 and need to get another prop because one of the fins on the original part is cracked. I see replacement props range from ~$70-~$150, depending on brand, pitch, material, etc. If I am replacing the prop anyways, is it worth it to get a stainless prop or should I stick with an aluminum?
Since I am replacing the prop anyways, this may be a good time to talk about the performance of this outboard. This motor is mounted on a 1973 Sears aluminum 13.5' Vhull. I don't know how much the boat itself weighs, but at the bow, I have a screw on trolling motor (~10lbs) and battery (~65lbs?). At the stern, there is the outboard (~90lbs), 6 gallon poly gas tank (~38 lbs full) and myself (~220 lbs) and there is probably 15 lbs or so of fishing gear and misc equipment spread out throughout the boat. Under this setup, I get 18 mph (smooth water, no wind) on a GPS app I downloaded to my phone. When my 115 lb wife sits up front, that drops to 14 mph. Does this speed sound right? From what I'm reading that sounds a bit slow, but I know the weight up in the bow probably isn't helping matters. I've tried various trim angles and no change in angle seems to make a difference.
I can provide background info on the motor itself if needed, but it runs great, just slow. I had just gotten a tachometer for the motor and had intended to see what RPMs were at WOT before I realized the prop was in bad shape. Maybe it needs a different diameter or pitch? Current is 9.5x10".
Thanks for the help!
Sam
Sam
