Very low usage motor (only 155 total hours), on last outing, ran out of fuel, but ran fine after refueling. Motor has sat unused/unstarted for past 2 months.<br /><br />Primer bulb gets firm, but loses firmness after several starting attempts. Noticed fuel leaking from vapor separator cover when squeezing bulb, replaced vapor separtor cover gasket, no more leaking, still won't start.<br /><br />If choke is applied manually on the primer silenoid, fuel will leak around the switch when squeezing primer bulb, but does not leak if manual choke is left in normal position (is this a real worry?)<br /><br />Followed starting procedures as posted in site FAQ, after spraying fuel mix directly into intake engine fired almost right up (unwarranted elation on my part!) but died as applied fuel was spent.<br /><br />I then was able to keep the motor running indefinetly by intermittently pushing in the key to apply choke when it sounded like it was about to die (about every 2-3 seconds).<br /><br />What could could cause all six carbs to not deliver fuel yet allow the primer selenoid to deliver the fuel?<br /><br />Thanks in advance
