Evinrude 150 hp gas hog ?
Capt Mike
I just got a 18'stratos bass boat w/a 150 hp 1990 xp motor(evinrude)went out other day approx 40 mi.and used 15 gals high test gas@4000rpm,correct prop is on and calm water runs fine but does gas consumption seem normal? Thank's in advance Capt Mike also any clues to improve mileage?
ktwheel
Re: Evinrude 150 hp gas hog ?
I have same similar boat and problem. I have an 88 Stratus with Evinrude 150HP XL motor. A problem that I am having is not only high gas consumption but battery not charging. I pull the battery out and fully charge it. I put it back in and a few hours into day battery drains and doesn't charge. Tried every test imaginable even tested battery for dead cells. All good. bad Stator ? Do you have any info on this or know anyone who could.
Capt Mike
Hey kt wheel had same problem week before last had to replace.regulator/rectifier (200$)all ok now charging 14 volts now.
twochipmunks
sell that pig and get a suzuki 140.. can run all day on six to ten gallons.
D
DJ
Guest
DHadley is right, save a few bucks and run what is recommended-87.<br /><br />The 150 is NEVER going to be miserly when it comes to fuel.<br /><br />Chipmunk must be talking about a four stroke. My last DT-140 (2 stroke) would burn 10 gallons of gas a day--idling. And it wouldn't outrun most 115's.
bmurray
I made a post recently asking about fuel milage. I sure mine is much worse than yours. It's an 85 Johnson 150. I have heard that it is the true mama sow of the gas hogs!
Dhadley
Any motor improperly set up will be a gas hog compared to those set up correctly.<br /><br />Just a thought!
twochipmunks
the 140 i was refering to is a four stroke .. and i will out run any 150... especially since they have to stop at the gas pump all the time..
wilde1j
Mike, rule of thumb for 2C OB's: HP, move decimal 1 place to left= GPH (@ WOT). If you ran your motor at or close to WOT, 15 GPH is about right. Reducing power to 3500-4000 RPM saves a lot of fuel.
Ted S.
You guys are on the right track. My 71 Johnson 125 will burn about 10-12 GPH at wide open throttle. If you back off and keep the R's below 4000 it drops almost by half. Problem is its tooooo boring at that speed! :D
