Lighthouse
- Joined
- Apr 7, 2003
- 1
I hope someone here can help me out. My 1992 Evinrude 150 recently started idling around 1100 -1200 RPMs, ( no load ). I checked everything my shop manual said to check, ie: vacumm leak, timing, Quickstart circuit, temp sensor, throttle lever and cable adjustments, etc. The only thing that is not checking out is the Quickstart circuit. When I first start the motor when warmed up it revs up to 1200 RPMs, then in about 5 seconds it drops to around 900 RPMs, but then slowly increases back to around 1100 RPMs. I initially thought the Quickstart was working because of the RPM drop, but upon checking with a timing light there was not any timing change. Even when pulling the temp sensor connector there was not a timing change. However, the timing is currently at 9 degrees ATC, so it is already retarded further than it should be and would only idle higher if I advance it to the recommended 6 degrees ATC. Also I have sprayed around all the intake gaskets and vacuum hoses, and can not find any evidence of a vacuum leak. So does anyone have any ideas of what might be causing my problem. I'm trying to avoid having to take it in to a shop if I can take care of it myself. Thanks for any help you can provide.
